Kpackpackkelley
Jul 25, 2013Explorer II
There are two tiers to the housing just take the top one off and make some full revolutions of the flywheel. Also with a multimeter check your volts when you engage the starter you could have a dirty connection on the start soileniod or battery. Check all your connections from the battery all the way to the starter when you push your start switch.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
