Kpackpackkelley
Jul 26, 2013Explorer II
I'm calling the blower wheel the flywheel I'm sorry. Once you take you top cover off you can turn the blower wheel by hand or put a socket on the bolt . Then we will know if the piston is stuck or the valves are stuck or need adjusting you may also check your bearing on the other end may need some oil or grease in it. Do you have the parts manual ?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
