ashlatz wrote:
Model # 4kyfA260100k
That uses the 981-0530 manual. I have a 981-0530C, which is probably the same. Your gen produces fault codes and it's the next step in the troubleshooting guide. What's the fault code?
If there's no fault code, then let me know that. Either way, I can post the relevant part of the troubleshooting guide.
If you post an email, I can send the manual. Usually I can find them on the web, but not this one..... OOOPS! I found it:
www.cumminsonan.com/www/pdf/manuals/981-0530C.pdfHere's how to read the codes:
FAULT CODES
The genset controller provides extensive diagnostics
by causing the status indicator light on the Control
Switch to blink in a coded fashion. Following a
fault shutdown, the indicator light will repeatedly
blink 3 or 4 blinks at a time.
Three blinks indicates a service fault. Press
Stop once to cause the two-digit, second-level
fault code to blink. (Pressing Stop again will
stop the blinking.)The two-digit code consists
of 1, 2, 3 or 4 blinks, a brief pause, and then
1 to 9 blinks. The first set of blinks represents
the tens digit and the second set of blinks the
units digit of the fault code number. For example,
Fault Code No. 36 appears as:
blink-blink-blink—pause—blink-blink-blink-blink-blink-blink...
Four blinks indicates that cranking exceeded
15 to 20 seconds without the engine starting.
Note: Fault Code Nos. 3 and 4 are first level
faults. Avoid interpreting them as second-level
Fault Code Nos. 33 and 44, which have not been
assigned as fault codes.
Restoring Fault Code Blinking – The fault code
stops blinking after five minutes, or after clearing the
fault by pressing Stop once for a Level 1 fault or
twice for a Level 2 fault. Press Stop three times within
five seconds to restore blinking. Note that the last
fault logged will blink, even after the condition that
caused the shutdown has been corrected.
