Ranger_Smith
Feb 12, 2015Explorer
INVERTER UNDERVOLTAGE FAULT—CODE NO. 13
(Controller not able to regulate to rated voltage)
Corrective Action: Check whether the vehicle engine and genset share the same starting battery. If so, and this fault occurs when cranking the vehicle engine, low battery voltage may be causing this shutdown. Increase battery capacity or install a separate battery and battery charging system for the genset.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
