One_Florida_boy
Feb 13, 2015Explorer
Ok guys quick update,
I've eliminated the issue is a result of low voltage in the house battery. I put a fully charged jumper back on the house battery and I have the same result. It runs for a short period of time and shuts down.
I don't think it's a carb issue either, it runs to good when it's running and when it shuts off it's just like you turned it off, no sputter, no coughing it just shuts down immediately.
I will try gravity feeding it tomorrow with a gallon of fuel and a bottle of Sea Foam. I believe the controller/microprocessor is killing the ignition because of a gen voltage issue as the trouble codes 12 and 13 indicate.
If that's the case I will have to try and find info on how I can test that. Thanks for all the help guys, update tomorrow.
Dave
Dave
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
