j-d
Feb 14, 2015Explorer II
If it has ATS (Automatic Transfer Switch) the ATS is probably near where the Shore Tie Cable enters the coach. Ours is under the bed, near the Power Center (Breaker Box).
If it doesn't have ATS, there's a Receptacle (like the ones on campground power pedestals) near where your Shore Tie Cable is stowed when not in use. Probably in the same compartment. Receptacle is powered by the Generator. You plug your Shore Tie Cable into the Receptacle and your coach is powered like it was on a campsite.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
