j-d
Jun 17, 2016Explorer II
Welcome to the RV Community
You're welcome for our help, and
Thanks for posting the resolution.
Our first RV had "Generator Prep" which was some wiring, not even a fuel line. I installed a used generator, and found that it was designed for "manual transfer" with a receptacle. The box was there, blank plate over it, and BARE wires inside. Not just cut, but stripped, so lots of bare. I stumbled through the install and wiring. Ended up with "manual" but there was also a convenient "generator outlet" in the kitchen. I think the idea was to use microwave or some other single appliance without having to do out and do a "transfer."
We drove that RV in "transfer" so we could start the generator (I was able to wire an indoor Start/Stop switch to wiring they buried in the wall without marking it) without going outside in a rest area, etc.
The only disadvantage I ever saw was middle of the night in a thunderstorm power failure in the campground. When THAT happened, I had to go out in the rain to "transfer" which I think happened only once or twice.
Automatic Transfer Switch (ATS) is nice, but it's a potential point of failure that hard wiring doesn't have.
Back to it... Don't hesitate to ask questions. It's possible that a good answer isn't even on the path you're taking through the problem. Chances are, somebody has been where you are, before.
Thinking we'll be hearing from you often. Hope so...
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
