beachinn's avatar
beachinn
Onan Microlite 2.8 genset runs but no AC output
I just purchased a 1990 Winnebago Warrior in very good condition, but I cannot seem to get the onboard generator to produce voltage. I have checked the circuit breakers inside and the breaker switch on the generator itself. Can anyone offer any advice?
Thanks Mark
  • j-d's avatar
    j-d
    Explorer II
    Does the coach have an Automatic Transfer Switch? If it does, it could have failed. If it does NOT, then the genset powers a receptacle, probably where your shore tie cable is stored. You have to plug the shore tie into that receptacle to power your coach with the genset.
  • I did shut off each breaker in the main box inside and flip them back on. I also looked at the small fuses. As for the junction box, I am not sure where that is located? All of the wiring seems to be firmly in place.
  • There will also be a breaker in the main distribution panel, check it also.
  • Welcome to the forum.
    Did you turn the breakers off and back on? If not, try that.
    Don't just look at them, sometimes they need reset.
    Always try the simple, easy things first.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
