powderman426
Nov 15, 2014Explorer
Check the wire wound resister in the start circuit. On startup it bypasses the resister so it has a higher start voltage. If the resister goes bad the circuit goes open when you release the start button. You can check it for continuity with a vom.
Forget tha above. I finished reading your post and that cant be your problem but i thought i would leave the info in case someone searches and has the problem where it only runs while holding in the start button.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
