j-d
Sep 28, 2016Explorer II
Is the genset far enough away from anything that's a fire or explosion risk? If so, try jumping the starter motor direct to 12VDC. Since the 2800 has a logic board, I think I'd disconnect the 12VDC "Hot" side from the rest of the generator for the start attempt.
Gas fumes or spills are obvious risks, but so is a Battery. Work too close to one and sparks can cause an explosion from battery gases.
THANKS for posting Model and Spec. Many don't.
This Link is for up to Spec "D" but might be of some help to you.
OH, as you check power and wiring, never neglect the GROUND. All too often we spend our troubleshooting on only the HOT side of the circuit.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
