MrWizard
May 03, 2020Moderator
fill the gas tank at least 3/4 full of fresh GAS, the pickup tube for the generator is located approximately at the 1/4 full level, this is so running the generator will Not leave you stranded with an empty GAS tank, once gas gets
below that level the generator will not run , it has no GAS, also check the oil level in the generator, they have Low oil sensor, that will shut down the generator
