Handbasket
Jul 27, 2013Explorer
Full identifier would be model name, and all info on the data plate.
_If_ it's a Microquiet from the past decade +, it gets cranking voltage and ignition from the battery, but self-generates to run the ignition & fuel pump once the start button is released. All Micro-series carbs for at least the past 12 years are non-rebuildable.
Jim, "IRS: Be audit you can be."
