DrewE
Sep 13, 2020Explorer III
What part exactly are you considering to be the "generator frame" as opposed to the "generator"? The usual chassis ground connection on these generators (for the 12V system) is from a bolt/stud on one of the corners of the pan part of the generator housing, the inside of which has a sort of star or bottle-cap shaped washer with a few smaller ground wires connected. The starter motor has a ground lead attached to it, but I'm not sure offhand where it connects to the generator chassis; if memory serves, it wasn't along with the bottle cap shaped washer thingy.
If I'm understanding your post properly, it sounds as though the ground connection between the generator and the chassis of the motorhome is not good. These connections need to be solid as the starter motor requires something on the order of 100 amps when cranking.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
