N-Trouble wrote:
"Microquiet" what a joke of a name. Wonder who the genius in their marketing dept that came up with that.
Hmmmmmm .... I wonder what other 4000 watt constant-speed generators out in the open in just the cabinet they come in have a noise level of around only 60 dB(A) @ 50 ft (National Park Standards) at one-half power?
The (current) Onan 4000 does this. I believe that the 11 year old model in our Class C motorhome even has a spec of only 66 dB(A). Of course certain variable-speed (inverter) generators, such as the 3000 watt Honda EU3000iS are quieter - but they may not be of the right size, power, and weight for small motorhomes - as the Onan 4000 is.
How quiet and vibration-free they are when mounted in RV's is up to the builder of the RV. They have to be mounted on high quality isolation mounts and they have to be mounted in cabinets closed on all sides except for the bottom - with none of the green Onan case visible hanging out the cabinet openng at the bottom.
The Onan 4000 decently installed by Winnebago in our small motorhome is fairly quiet and vibration-free ... considering it provides 4000 watts constantly on tap at all outside temperatures ... including extreme desert heat in the summer. There is very little vibration in our coach floor. We sometimes nap in the middle of a hot day while our Onan 4000 is powering the A/C. We have left it running the A/C almost throughout the entire night in the Southern U.S. in August so that we could sleep in the extreme heat and humidity.
I feel that the Onan 4000 sometimes gets a bad rap through less than optimum installations by some RV manufacturers.
However, a similar physical size and weight 4000 watt variable-speed inverter generator designed for permanent RV installations would certainly be a welcome appliance in new rigs if it was as reliable as the Onan and priced not more than say, $500-$800, above the price of the ~$3K Onan 4000.
