alwaysfixinsome's avatar
May 19, 2016
Onan Microquiet 4000
Hello, 1st post but have read & searched through so much over the last couple years. Will probably say more than necessary but sometimes more info helps. This generator not installed in rv, yet. Bought out of another rv & ended up installing a new carb. Ran the carb a few times & let it run out of fuel. It did sit for a couple months though. Had it outside for awhile & a very industrious mouse set up home in the coil area (if something doesn't move for a day or two it gets occupied by these pests & they pack things quickly...these rural farm mice are very industrious) It was a chore getting everything cleaned out! Not sure if might have disrupted things while cleaning. Do know the choke spring became dislodged but think put it back right. Thought it would go into one of the holes but seems to just connect to the arm that bends down per some pics posted elsewhere on this site (excuse my lack of proper terminology). I'm someone that can usually repair mechanical things but sometimes get myself into trouble & folks like you have always helped me figure things out. The electrical stuff is where I am more wary to venture unassisted.
Wired an outlet to the generator & have plugged in a compressor & heater. The heater is 1500w. The compressor 13.8 amps. If the compressor shuts off the generator shuts down with overvoltage code 14. If generator & heater running all goes well & have run it for 3 days of 2 hrs each until gas ran out or shut it off. If I try to plug in & turn on a hairdryer 1875w in addition to the other two it will shut the generator down. Does this sound like proper running?
Reason ask is the friend that wired the electrical outlet fiddled with the throttle stop screw. The generator previously ran & has a black mark on the butterfly where it usually contacted the choke lever?. These marks were on carb from factory & that is where it ran before. Now it runs with much more of the butterfly forward of the lever.
I want to make sure this thing is running as it should before installing it. Also, have been running 100% gas plus seafoam thru it. It seems to like the seafoam addition and doesn't start without manual assistance pushing the butterfly with just the gas. With the seafoam it will start & continue to run 1st try as long as get load put on it right away by turning on heater then compressor. But if no load quickly it shuts down. Could I have a bit of varnish that needs to yet be cleared out?
Onan Microquiet 4000 4KY FA26100J spec J, S#G010263059
Have manuals & trouble shooting guides but not sure if have a problem or not. ideas & any input appreciated.
  • "Microquiet" what a joke of a name. Wonder who the genius in their marketing dept that came up with that.
    Sorry, everytime I see that name I cant help myself.
  • j-d's avatar
    j-d
    Explorer II
    There are a few carb/choke linkage pix on this site. I have some on flickR that I'll try to find later.
    I think the "idle" passage(s?) in that carb may be gummed up. It doesn't take long and running out of gas doesn't dry the whole carb out. I put "idle" in quotes because even though it's a 3600-RPM unit, it needs idle passages to run with little or no load.
    Let me know if you need the pic.
