Yes but my issue and troubleshooting to date match the original post exactly so was hoping the original poster might respond with what solved their problem. Figured it was a long shot but worth pinging them if it can expedite me finding a solution.
SouthernLoco hasn't posted on the forum since 2016. But lots of folks on here (well that used to be on here) are familiar with genny issues. I think you'll get more traction if you posted a new question.
That said, code 58 is High Exhaust Temperature. From what I've read it usually comes from running too lean. If cleaning the carb etc does not fix your problem, some folks have had luck replacing the fuel pump and filter.
The root of these problems is usually when the genny sits dormant. The fuel will varnish. It's recommended you run your genny once a month under a load for an hour or so to help mitigate some of these issues.
