jeremywatco's avatar
jeremywatco
Onan shuts off while driving/hot
Hi there,
Having an annoying issue with my Onan 4000 gas generator that is only an issue while driving the motorhome. While stationary its perfect.
So if the genset is running while driving down the road we have found that if it is really hot out and/or driving up a grade while it is hot out the genset will shutoff and refuse to run until conditions change.
The genset is located right behind the engine on our 2014 Fleetwood Storm and by thinking is that excessive engine heat is making its way to the genset and causing it to overheat.
I've made sure oil levels are good and that the fuel level is good.
Yesterday I was driving home from the Sierra's and it was about 109 degree's outside. Wasn't the best drive home when the coach A/C couldnt be ran as the generator wasnt cooperating.
Any thoughts? Anyone else having this issue? If it is a heat issue I am wondering if there is some way to modify the genset compartment to allow better outside ventilation.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
