Nikki carbs are used on a lot of different small engines but basic principle should be very similar between versions of the Nikkis.
Found a video
HERE of one used on a B&S engine which shows you have to remove the float and float valve and then you have a plastic piece that needs removed. Once removed you will see the emmulsion tube which normally is covered by the plastic piece.
They say a pix is worth a thousand words..
From the video in link above..
Plastic piece after float has been removed, see the red line I added.
Click For Full-Size Image.
Emmulsion tube hidden by the plastic piece, see the red line I added..
I know there are a lot of variations of Nikki carbs, but the emmulsion tube typically will be in the exact center of the fuel bowl. In the case of this Nikki, it is hidden in the center of that plastic piece. Most carbs this tube is hidden inside the metal post and is held in place by the jet.
