LittleBill
Jan 27, 2021Explorer
are you sure the spark is good? pull the gas line off and prime it should be pumping a decent amount of a fuel
i have a 4k 2000 era onan, it starts perfect, but starts cutting out, i have determined the coil goes weak and stops firing. i just got the ignition coil, my generator has to come out and be taken apart to replace. it was 12f here today, its going to be a while
if you pull the air filter and spray carb cleaner and it doesn't pick up, start looking at spark closer.
