Diesel_Camper
Aug 29, 2016Explorer
I don't see any problem with that. You could just unplug the wfco from the 120v outlet and abanon it in place. WFCO is junk anyway, add to that a long wire run and you have batteries that never get a full charge.
Edit: You probably still need the WFCO for the converter function, so if it's not on a seperate breaker, you could wire up a 120v switch and just turn off the WFCO when you want to use the smart charger. Running both chargers at the same time could interfere with the smart charger.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
