time2roll
Aug 29, 2016Nomad
Yes you can bypass or disconnect the WFCO. Once the air is started I would reconnect. By the time the air cycles the battery should be charged enough that WFCO draw would be minimal.
How many amps is the portable? It will also create quite a load depending on rating.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
