time2roll
Aug 30, 2016Nomad
MEXICOWANDERER wrote:Yes it shuts down once battery voltage rises to the WFCO set point, typically 13.6 volts. However if you use that charger at low amperage it may take an extended period to reach that voltage. Or you can put the portable up to the 30 amp level for faster charging however that will also load down the generator.
The WFCO shuts down 100% when it senses another charging voltage source. A parallel charger does not damage the WFCO it merely shuts it down. Same for switched power supplies like the Megawatt and Meanwell.
I think the idea is to get the air started and then switch the battery charging on.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
