gbopp
Jul 19, 2016Explorer
First, I would pull the spark plugs and see if the engine turns over and is not seized.
If it turns over:
Replace the fuel filter. It's probably clogged.
The fuel line may be collapsed, replace it.
Replace the spark plugs.
Clean the battery electrical connections.
Use Seafoam or Berrymans to clean the carburetor and fuel line. Don't waste your time with WD-40. You need the inside of the carb cleaned. There are small ports that will probably be clogged.
Charge your batteries and try to get it started.
If it has not been used in years, it may start but not put out any power. You may have to Flash the Generator.
These are simple, relatively cheap steps to get the generator working. Try them before you spend a bunch of money.
Make sure the RV has at least 1/4 tank of gas. The generator pick up can only use the top 3/4 of the tank. That's so you can't run the generator and drain the fuel tank, leaving you out of gas.
Keep us updated on your progress.
If it turns over:
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
