nuget102's avatar
nuget102
Explorer II
Jul 19, 2016
Onboard generator 1987 Lakeview Suncrest
So I recently bought this RV for $2000. They guy threw in a generator that needed a pull cord replaced (which he didn't know how to do) but the RV had a onboard generator.
I really want to get it working, if for nothing else as a backup in case the other one is stolen, which may happen since the locks on the rv are kinda... iffy.
Far as I can tell the generator is stock, and if it's not it seems to have been put in properly. The guy I bought the rv from says the generator has never worked. He's owned it for five years. I'm not too savvy with generators, I've dealt with motorcycles and cars. But never a generator. Don't know if they're really different at all, I get the concept that it basically runs an alternator but beyond the actually look and interior I know nothing. In fact I've never even seen a generator in person until I bought this RV.
So aside from the obvious of changing oil and draining the has, which is redundant since it runs off the has tank. What else should I do? For all I know it's possible this thing hasn't ran since the 80s. Should I strip it down and wd40 the hell out of it? Or should I try to actually getting it running? It has a starter so maybe it's just as simple as the starter motor?
  • So I checked the generator. The starter motor isn't making contact with the crankshaft. Causing that unbearable noise. I have to some how readjust the starter to make full contact.
  • j-d wrote:
    Thanks. I'll put that in the main post, hopefully pictures will work then.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
