Big_Katuna
Jul 24, 2015Explorer II
I have worked a lot with shunts and meters building load boxes when I was a tech in a switching power supply lab.
I am going to speculate that it will work fine and easy to try.
If the shunt runs at near max rating you might consider a fan as higher temps will affect accuracy but not much.
BTW You can remove material from the shunt to tune it to whatever drop you need.
