PeterCutter's avatar
PeterCutter
One Charge Controller for House and Start-up Battery??
Hello everyone and thanks for having such a great forum. This is my first post though I have been trolling and learning for some time now.
I have a 34 Ft. Airstream Cutter with a Ford 460. I would love to install a solar panel system to charge the batteries. I have two 12V house batteries located inside the RV under the doghouse and one 12V battery under the "hood" that starts the RV.
I would like to know that is use the TriStar MPPT 60, will I be able to use that controller to charge all three batteries or will I need two separate controllers one for house batteries and another for the engine's start-up battery? If I need two do I need MPPT for both (two Tristar MPPT 60)? Can I go with something more affordable with Tristar MPPT 30 or can I even use something like a Xantrex C35 charge controller for the truck battery?
Frankly, I am electrically-challenged (flunked out of electrical engineering school) and I am super confused about this whole process.
Thanks in advance,
Peter
  • I use our solar system to charge both house and cranking battery. Installed a switch to de-energize the isolation relay between house and cranking battery that came with coach. I keep an eye on the house batteries charging current and when it starts to taper off I'll energize the isolation relay for 1 to 2 hours then drop it back out.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
