westend
Feb 06, 2013Explorer
I would mount the inverter as close to the batteries as possible. The spec sheet for a 600w Samlex inverter calls out 8ga. wire at 1.5 meter, maximum. You will need larger wire for bigger inverters. If I didn't already know how deficient the DC wire was in most RV's I'd suggest a plug in 300w inverter for the TV in the bedroom. It would save time and expense. You just can't be sure how the mfg. decided to connect your DC receptacles. It may result in loss of the inverter or loss of the device powered. The better solution is to mount an inverter close to the batteries and pull a new length of AC to the desired location.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
