mena661
Feb 06, 2013Explorer
Just Jeff wrote:Manually switch to LP but I only run my fridge on LP so no problems remembering that. Unless you have solar, no battery charging will occur while on inverter power but you MUST remember to turn off your converter first. I installed a 30A RV plug in the same compartment that my shore cord is located so I can run my inverter on the road if I want to like BFL mentioned.
Mena - Do you run your fridge from the batteries/inverter, or do you manually switch the fridge to LP? Thinking battery bank capacity here.
The other end goes to a 20 amp plug that goes into my inverter.
EDIT: Just noticed you have a MH so, yes, you'll get some battery charging from the alternator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
