westend
Feb 07, 2013Explorer
You do realize that you'll need two of those 6v AGM's to make them work? That is going to be > $1000 and shipping, plus the additional expense of the chiropractor to get your back fixed after installing them.;)
FWIW, 6v GC2 Sam's club batteries X 4 = $400 with around the same capacity.
For a 1000w inverter at it's full load, you'll need #2 AWG wire and mounting the inverter within a few feet.
You might want to look into a wall mounted, vented propane auxiliary heater in lieu of electric. They use a lot less propane than the typical RV furnaces and are less noisy. Some of this is dependent on how your plumbing system is installed. Some coaches have supply and drain lines outside the heated cabin and rely on ducts from the furnace to avoid freezing.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
