D_E_Bishop
Feb 07, 2013Explorer
I have a 100 watt inverter that runs the front TV which is a small flat panel w/a DVD player built in. The TV draws 35 watts. The rear TV is also a small flat panel but 12 VDC, I have an 80 Watt inverter for the DVD player. I'd rum both off the 100 watt inverter but the wirering is a pain, it was much easier to install another 12 VDC circuit to the 80 Watt.
If you are handy and understand the wirering, rewire the 1000 Watt inverter for both and other small draw things. 1000 Watts is quite a bit of power.
Then again I don't know anything about your rig or your TVs.
I didn't read all the posts so I missed out on you wanting to run heater and all that. Disregard my post.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
