westend
Feb 09, 2013Explorer
Just Jeff wrote:I found it necessary to "choose a store" when searching the Sam's Club website. Not all their batteries are available at all locations.
Westend - do you have a link to those batteries? I'm not getting any results at samsclub.com.
The upgrade path you're considering is starting to become a fairly large and twisting road. I believe you're getting into having some engineering questions to be answered, i.e. weight distribution, clearance issues, wiring concerns, etc.. It may be time to step back and further analyze your power needs and see if some usage can be trimmed. If not, and if you want a maintenance free/limited access solution, AGM type batteries will be your best bet.
Further, your marriage to the Pelonious heaters is where your power $$$ seem to be flowing. I would consider a quick divorce from that heating solution. She will require too much power and unnecessary cost. Just for a ball park estimate, you will be spending thousands to equip your rig to enable the electric space heaters versus using one vented propane space heater at considerably less cost.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
