pianotuna
Feb 09, 2013Nomad III
Hi Jeff,
Leave the OEM converter in place. Add another one closer to the "new" battery bank. Make sure the additional charging source is protected via a circuit breaker. When there is adequate shore power you may find that the two converters may "play well" together.
"Mr. Battery Charger" on the forums is BFL13--he has used up to five charging sources at one time if I remember correctly.
Just Jeff wrote:
Since the power panel is in the back I guess it makes sense to leave the converter back there...but that means the wire from the converter to the battery has to travel a long way.
The battery station is near the shore power box, and there's a 120V junction box there. Would it make sense to run a 120V wire from that junction box to a new 3-stage charger at the new battery location? Just bypass that converter for battery charging purposes.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
