mena661
Feb 09, 2013Explorer
How short is that 1/0? If it's longer than a couple of feet, go larger. You want LOW voltage drop for high draw items. Although you can probably get away with the 1/0 on a long-ish run (6 feet) if the high draw item is on for 10 minutes or so. If you go to 15 plus minutes, you need larger wire.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
