time2roll
Feb 10, 2013Nomad
Class T is a slow blow fuse. I would go 150a with 1500w.
If the wire is short, well protected, no hidden areas I might skip the fuse and go up a wire size.
Those ring terminals look flimsy. Here are some closed lugs:
http://shop.genuinedealz.com/heavy wall lugs
If you can measure well they can make up the cables to any cusom length or size for a nominal fee. Pro crimp and heat shrink sealed.
http://www.bestconverter.com/Class-T-Fuse-Block-150-Amp_p_216.html
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
