GampawsBigTruck
Feb 10, 2013Explorer
The one thing to remember is amps=watts divided by volts. it means a 6amp apartment type fridge (for 120volts) will draw 60amps upon start from a 12volt inverter. This I figured in to my larger apartment type fridge to replace my cooked R.V. fridge(due to high ok. temps). when the fridge starts there is a very high draw, running however is a relatively low draw. Therefore the truck alternator keeps up fine until we get to shore power. If we had a good gas fridge she would run all the microwave use(minimal) and T.V.(also minimal) on the little battery backup I have, without running the genset.Any amps at 120 volts through an inverter is multiplied by 10 in order to see the initial draw on 12 volts.(in ideal situation).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
