mena661
Feb 10, 2013Explorer
pianotuna wrote:There are some configuration settings that can ONLY be done with the Magnum remote panel. I'd suggest getting the Magnum panel.
Hi Jeff,
I prefer separate components. I'd go with just an inverter--and if necessary upgrade or replace the converter. That's also about $400.00 cheaper to do than having the inverter/charger selected.
I don't understand what the remote panel on the inverter does.
I'd suggest the Victron monitor instead of the Magnum.
smkettner wrote:I agree, I don't think 4/0 is necessary for that short run. 1/0 can do 242 amps and the voltage drop over 3 ft at 150 amps is well under 1%. If you ever need more amp capacity you can add two more 1/0's (you can do this per NEC code).
Since surge performance is not a huge deal in an RV I would stay with 1/0, maybe 2/0 at max. Only $1.10 more per foot so less than $10. 4/0 jumps $4.50/' (Genuinedealz, shipped by the foot, assembly available, no tax)
What is the largest load? 1500 might be small for a full size microwave.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
