Just_Jeff
Mar 09, 2013Explorer
How do I know if anything is wired directly to the battery and doesn't run through the 12v distro panel? I looked on Jayco's schematic and it's not clear. Does EVERYTHING normally run through the panel?
I'm asking b/c the way I'm picturing wiring the new setup is like this (ignore the periods):
...........Gen\
..............Transfer Switch---Inverter---120V Panel---Converter
Shore Power/.............Batteries/
There really won't be a way for the battery system to power the 12v system directly. Is that ok?
I can leave the current battery where it is but it'll need to be maintained.
Again, big thanks for all the patience in this thread. I'm getting closer to the install but I still find new things to consider whenever I search!
...........Gen\
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
