time2roll
Apr 03, 2013Nomad
For 100 amps you will not be able to use any oem 12v connection. You pull new wire based upon use. Is that a 2000w Magnum? I recommend 4/0 wire direct from inverter to battery. The install manual should cover this.
http://shop.genuinedealz.com/Marine%20Grade%20Wire/Marine%20Battery%20Cable/0000%20AWG%20Battery%20Cable%20UL/
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
