Rmack1's avatar
Rmack1
One or two generators?
I have two Yamaha EF2000iS generators, and they work together through the connecting cable.
My question is; is it always necessary or desirable to have both generators running? I know I need them both for the AC, but what If I'm just watching HD satellite TV? I'm thinking it would be a good idea to have two running if I use the microwave, and I would probably turn off the AC before using it, but I'm not sure.
I'm thinking that if the AC or microwave isn't being used, it might be more economical to just have one going, and alternate between the two.
Anyone know?
  • Just did some quick research.
    If I get a 1000 watt inverter, will that work for everything except the AC and microwave? It would be nice to have the TV during quiet hours in campgrounds.
    How big are these things? I have a small 22' trailer, though it has an amazing amount of living space due to the Murphy bed, but where would I put it?
  • BFL13 wrote:
    For watching Tv etc all you need is an inverter that draws from the batteries. Then you use your generator(s) to power a battery charger or converter or inverter/charger to recharge the batteries when it is during "generator hours."
    A newbie guy parked near us used his gen in the evening to watch TV because he had never heard of an inverter! Lucky for him I didn't have my Bazooka handy. :)
    You need two 2000s for when your continuous load will be over 1600 watts, otherwise one will do. Your microwave probably wants 1500w so if you are also battery charging (1200w? maybe less depending) you will need two anyway.
    I didn't know I needed an inverter, and thought I needed my gens to watch tv, also! I guess I need to check out inverters. Any suggestions for my 33amp TT?
    Do inverters ever come as standard equipment? If so, why don't I have one? I bought a brand-new 2013 Forrest River Rockwood Mini-Lite.
  • For watching Tv etc all you need is an inverter that draws from the batteries. Then you use your generator(s) to power a battery charger or converter or inverter/charger to recharge the batteries when it is during "generator hours."
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
