wa8yxm
Nov 30, 2020Explorer III
arcsum68 wrote:
Per the video when you use the switch on the showerhead to shut off flow, the cold water will back fill into the hot water side since the pressure is greater and thats why when you turn it back on it will be cold for a few seconds.
Since both the hot and cold water are pressurized by the self same PUMP that.. it male bovine produced organic fertilizer (AKA BS)
What happens is when the water stops the hot cools a bit and "Contracts" sucking cold in. The solution is to use a better valve that does not 100% turn off flow. the Oxygenics "Smart Pulse" valve is like this. it allows a dribble of watter to flow. So does the generic valve I got at Mennards years back (Alas no link it's been 15 years)
Either of these solves the issue for about 10 bucks.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
