arcsum68
Nov 30, 2020Explorer
opnspaces wrote:
Are you having a problem with the cold water blast in the shower or does the one way valve just seem like a good idea.
Many RV water heaters already have a check valve at the exit line, it's possible yours already has this.
Does your RV shower head should continue to dribble water out of it even when you flip the switch off..
Thanks all for answering.
I get a cold blast every time, so it seemed like a good idea. If mine had such a valve, would this not be an issue or is what I have about as good as it gets? Pretty minor complaint, just trying to make things nicer.
I have an Oxygenics shower head and it does indeed dribble when turned "off".
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
