jjrbus
Jun 22, 2020Explorer
5500 watts should start a 13.5k AC with ease and 6300 surge is waaaaay overkill. The info I have from Duotherm specs a 3500 watt generator for a 13.5. I would suspect another problem.
Any inexpensive watt meter will not do you any good as they are not fast enough to measure LRA, locked rotar amps. Which is starting amps when the compressor first kicks on, lasts only a micro second. Is there another RV around you could hook up to and try and start their AC or can use their gen to try and run your AC, that might isolate the issue or hook up to shore power to test AC.
My best guess is the start capacitor on the AC is going bad, my way of dealing with it, not having the proper tools to test is to replace the start capacitor. Does not take an electrical degree and should be $20 or less, if it is not the issue, you have a spare capacitor. Google or you tube replace RV AC start capacitor.
Disclaimer, I am not an electronics guy, just another RV'er trying to get by.
