all4coop's avatar
all4coop
Only getting 8 volts from converter at battery connection
This started with AC compressor not coming on, checked all connections and there is no power going to compressor, compacitor is good but the start boost is not good (got one ordered). While trying to diagnose this problem I noticed the lights were dim. The fresh battery that was put in the camper now only has 6 volts. I checked all fuses at electric box and they are good, I am hooked to shore power (pole barn wired for camper). With the battery out the campers lights are dim and the slides will barely move. If this is my converter could it also be causing the AC compressor to not come on? I hooked a fresh battery to the camper but the AC compressor still will not start. Condenser fan and blower will work though. Thanks
