MrWizard
Jun 04, 2017Moderator
the Air Condionior, has nothing to do with the converter having low voltage
BUT if the converter is bad and not supplying enough power to charge battery or maintain what is being used, the battery will go low
once voltage is low, the thermostat and A/C controls will NOT function correctly
replace the converter, fix your 12v problems,
then work on the A/C if it does not start working correctly
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
