j-d
Aug 03, 2014Explorer II
Good Deal! Hopefully it'll keep working and thanks for the update.
Our house requires maintenance and it isn't being bounced down the road. It can be tedious but it pays to check connections now and then.
Let me throw in something I've seen, even though it didn't happen here: The connection between the flexible shore tie cable and the solid RV wiring seems to be prone to working loose. Can get discolored, burned, failed. An RV tech told my friend that the problem seems to happen more in RVs where the owners use a couple plug-in heaters in the winter.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
