NickG's avatar
NickG
Only two curcuits working on trailer wiring pigtail
Since I sold my travel trailer, it has been a long time since I towed anything until I rented a skid steer recently. When I hooked the trailer up, I found that the left turn signal and left brake light were thee only things working on the trailer. I didn't know if it was the rental trailer or my plug, but after years of it hanging there exposed to everything Michigan has, I knew the plug might need replacing.
Now that I am picking my new boat up tomorrow, I figured I'd take no chances and put a new pigtail on. I replaced the plug with the same type and wired it the same (obviously).
Using a test light, I see that it WAS my plug that was bad that day, and still is. I only have power to the left turn signal/ brake and reverse lights. No running lights, no right turn signal/brake, no constant power, no electric brakes.
Seeing that the plug is all new with carefully wired connections, I am stumped where to go from here. There is no break in the harness where a "T" connecter could be. The harness just disappears into the chassis and runs... wherever.
By the way, when I last towed my travel trailer over 4 years ago, everything worked.
Any clue for a fella? It is a 2004 GMC Savana 2500 series van.
  • Thanks. No luck. All fuses good. Maybe a job for a pro :(
  • Probably mice. They chewed through some of wiring in my last PU. I'd check fuse first.
  • j-d's avatar
    j-d
    Explorer II
    I know that (at least some of the) Fords have a second fuse panel for trailer lighting. Don't know if the GM units do or not. Does Owner Manual refer to one?
    Our Ford minivan has a second panel and it's in the driver side REAR of the vehicle, not anywhere I'd've thought to look for it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
