rhochnadel
Aug 10, 2013Explorer
Sounds like you forgot to put the pins in the tube first. Been there and done that, don't worry all is not lost. Vice grips are almost a necessity at this stage, but first you will have to put an 1/8th inch x 3" pin through the tube (make sure it cannot fall out). I learned by trial and error but I found you will need about 14 complete turns on the spring before you put in the safety pin. Probably will need someone to give you a hand. Patience is necessary but success will feel good. Good Luck!
