hershey
Aug 11, 2013Explorer
Heres the easy, SAFE way to rewind your awning.
Remove the arm from the side of the RV at the bottom...like you were going to use the arm as a post when awning is extended.
Use the arm as a lever to wind the spring back to its original tension. Facing the awning from the front, wind it counter-clockwise. When tension is correct, just replace the arm in its bracket on the side of the RV.
