TS21sso's avatar
TS21sso
Open circuit lamp
I have a WFCO ULTRA III Distribution center (Fuse Box)
This unit has an open circuit lamp on each fuse. When fuse is blown or removed, the lamps light up. Problem: A fuse blew when I was extending the awning. This should have resulted in the lamp to be lit, it wasn't, nor did it light when I removed the blown fuse. Is this due to a fault in the box, or some other condition that would cause both the short and the unlit lamp? Like a loose connection some where in the circuit?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
