mrekim's avatar
mrekim
Open Frame Vs Inverter With Heavy Loads
I'm trying to get a handle on the noise level of an open frame generator vs 2 inverter gens in parallel (Champion 3500/4000 and 1700/200).
My AC load with the gen on is 16-18 amps or so. I'm trying to determine if a pair of inverters is going to be significantly quieter than the open frame unit.
I have a heater that's about 12 or 13 amps. I was going to use that as a load and measure the open frame to determine noise level.
Should I use the same load with a SINGLE 2000 watt generator to compare or try to make up an 8 amp load and then add 3db?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
